4310316 begins
aearch
pleasant hill , ca
FIGURE I SHOULD SHARE MY CURRENT THOUGHTS
SO AM REALLY HAVING A TIME WITH THIS THING
SO THOUGHT ID PULL THE M5 UNIT SELL IT AND THEN
PUT IN A 3.5 FROM SOMEWHERE - WHICH WOULD BE JUST FINE
FOR ALL THE DRIVING IM GOING TO DO -
YET LIKE A DINK I SOLD THE CHERRY PICKER.
SO I CAN STILL RENT ONE EASY ENUFF.
\THEN THERES THE TASK OF GETTING SOMEONE TO DO THE ECU NONSENSE
THIS WEEKEND ILL GET THE HELL IN THE COMPUTER A SEE HOW FAR I CAN GO ON
THE INSTALL DIRECTIONS
ITS FAIRLY SIMPLE TO GET THAT DONE
AND THEN COMMENT
LOGAN MUST HAVE HAD ENUFF WITH THE FEW HOURS HE WAS HERE AS
HE DOESNT SEEM TO WANT TO HELP - AS MULTIPLE NO REPLY FROM MY CALLS
BUMMER. DONT HAVE ANY INFO ON HIS NEW SHOP TO CALL TOO.
aearch
pleasant hill , ca
JimStim 1.5 MegaSquirt Stimulator with Wheel Simulator – Assembled​
CAN I WIRE THIS IN AND GET THE MOTOR GOING??
THANS ALAN
milwaukeesk
Member.
Atlanta GA
AND THEN COMMENT
I thought Don offered up helping to pull the motor and drop in a 3.5 in an effort to see you get that beast on the road?
Apologies in advance if I misread that.
I think if you go with a B35 and a custom ECU you end will right back where you started. Stuck with a motor that needs tuning and won’t run.
Find a running e34. Pull the motor and computer. Don’t change or customize a thing. Use the battery and the starter from the donor.
Examples:
Wes
Tasmania, Australia
Just confirming that IT has since provided me with a new keyboard and some Zanex. Might be missing something here but question why a 'cherry picker' is required.
Is the car levitating, is Alan vertically challenged, or is stone fruit involved in some manner that we are all unaware of?
Suspect Logan is busy filming next X Men instalment.
Arde
Cupertino, CA
What, SFDon and me hand carried my engine into the car and drove it back from Oakland.
Great for your hip extensors and your core.
People think 3 liter engines are heavy, nope, the larger the displacement the more air they have in the cylinders.
aearch
pleasant hill , ca
MARKOS YOUR WONDERFUL AND CAN ALWAYS BE RELIABLE TO ADD
IMPORTANT INFORMATION AND SUGGESTIONS
I REALLY THINK ILL GO WITH THAT AS THE THOUGHT OF HAVING THAT ENGINE RUNNING IS
A REAL DREAM -LITERALLLY THAT A DEAM
SO ILL GET A 3.5 AND DRIVE THE SOB
OK
THANS ALAN
The Stim is an emulator that mimics a motor. So you can configure the Stim to behave like an S38, plug it into your megasquirt computer, and use the stim to build your base map. It is just a starting point and probably no better than a map that is available online.
There is only one true cherry picker.
Belgiumbarry
Belgium
why in "god's" name all that hanky panky stuff of injection on a M30 ? mostly the first old school ECU's ... why not triple webers ? cheap and proven reliable as nothing else !
nosmonkey
In Rust We Trust
London, UK
Just whack a 350 small block chevy in there and be done with it.
And before anyone starts, I am hiding in an imaginary wooden box in a secret location that renders me immune to the communal online rotten fruit pelting that I am about to receive for the above comment.
