Question regarding vacuum connections
For the sake of clarity I want to make sure I understand the following statement from this thread:
' I took Jerry's advice and have linked the vacuum ports of each carb to the corresponding port of the other via vacuum tubing - both ported and manifold connections - this smoothed things out considerably on its own.'
1.Does this mean that the intake (passenger side) of the carbs should be tee'd together the run to the distributor?
2.Should I do anything with the drivers side vacuum ports or just leave them capped?
Constructed a sync tool using the clear tubing/ATF method. Also used coolwhip tubs and a vacuum gauge I had on hand (Tee'd with shut offs) going to the top of each carb.
So I am in the final stages of the carb adjustment sync process. I just want to make sure I am getting the best possible performance and running setup.
Thanks for the help!!
