Any advice on the best way to clean these up?
Seams like they do not come apart
How have you found the results with the plating Kit? Those look greatI took mine apart, sandblasted, and then zinc plated and reassembled.
The trick, or at least what I did, was to drill out the dimples that keep the balls from coming out. Think I used 1/8" drill. Then I tapped the holes and used a set screw with a dab of silicon to keep them in place. Was not an easy job but worth it in the end. I even bought replacement balls probably from McMaster-Carr.
After the holes are drilled, they might have to be filed a bit to get out the balls and rollers. I got new rubber orings for the rollers.
Hope this helps if you want to go down this road. Of course one may not choose to have them plated, if they are in good condition, just clean them up add some grease and good to go. We have the luxury to zinc plate using a Caswell Kit.
Plating Kits - Zinc Plating Kits - Caswell Inc
caswellplating.com
jjs2800cs
Some pics
I have had mostly great results with the kit. I have been zinc plating, then chromate dipping now for nearly 10 years. The key as usual is in the preparation of the parts to be plated and keeping the various solutions baths clean (especially the actual plating solution) as they do over time get contaminated.How have you found the results with the plating Kit? Those look great
Great account of your experiences, Thanks!
