So I was dimantling a car, and discovered that some of the older info on the site is not quite spot on.
The attached photo shows the window with rod with the flat oval loop at the bottom. You remove the rear-most of the cluster of bolts below the vent window along with the adjacent Phillips head screw. The flat loop is stuck pretty firmly in a slot in the opening mechanism. S,o you can fit a small to medium Phillips head through the opening where the bolt used to be inside the loop to pry the vent window upward out of the slot.
At the same time, the vent window must be about 1/3 of the way open. The photo shows the underside of the opening that the flat loop must pass through in the trim. The angle is not 45 degrees as in older posts, more like 30.
Good luck!
Scott
Good luck!
Scott
