You could fix it yourself.
Odometer malfunction(s) are legend in BMW 2002s and 3.0CSs. The '02 crowd has long had the knowledge and ability to repair their odometers. Admittedly, those cars make it MUCH easier to access the innards of the speedo head.
I've done several 2002 odometers and assuming the coupe unit is similar: the gray gear to the right of the odometer number wheels is supposed to be fixed to the shaft but over time it slips and no longer drives the number wheels to the left of it. Result: odometer no workie.
The heart of the problem is fixed thus: remove the "axle" or shaft on which the number wheels and gray gear reside. Note closely the position of the gray gear. Carefully with a ball pein hammer, slightly dimple or peen the shaft where the gray gear sits, so that it no longer freewheels on the shaft. Reassemble and your problem should be gone.
You can even reset the gears to read all zeroes but this is likely a federal case, so I didn't and wouldn't tell you to do that.
Other respondents, there are other speedo repair shops but one is in some disrepute. Let's be honest (and I've forgotten which) and suggest via PM to the OP which not to do business with.
Also, if I've got this wrong, y'all can tell me. I will admit my coupe odo hasn't worked since I got it, almost 20 years ago. In that time there have been many 2002s...
Look here:
http://www.bmw2002faq.com/topic/83423-odometer-repair/?hl=odometer+repair#entry127020
And here:
http://www.bmw2002faq.com/_/technical-articles/body-and-interior/odometer-repair-r42
Now I will readily grant that Hans und Fritz, possibly under the influence of Helga, made the coupe cluster hellacious difficult to get into. Be they cursed for that. Then they made the little chrome rings crimp things together. Doubly may they be accurst. But it's still doable, and you'll have really nice clean instrument faces if you get into all them and clean the dust off the faces and from the backs of the glass. BTDT on my last 2002, only weeks ago, and the result is really nice. Now for the rest of the car... oops sold it already. Sheesh.
