New owner of 74 3,5 csi purchased in Dusseldof
bmwe91974
Copenhagen
I have also just bought a new gearbox Getrag 265 which should fit right in hopes that it is right because I paid 1000euros it.
Is it someone who can tell me that is :? tru
Honolulu
Honolulu Hawaii
Getrag 265 will fit. I hope you have the mechanical speedometer drive at the lower left rear, if I recall correctly, some did not.
But it will bolt up to your engine block.
Wonder why you bought a "new" gearbox for that much money when there are good used ones usually available for much less. But then I'm extremely frugal. Is it actually factory new, or reconditioned?
bmwe91974
Copenhagen
Oh yes garage but you need one when you live in the cold north (Copenhagen)
About my gear box I was told that it should be a 265 but it says something completely different for 262.0.510.00 225 3.1 what does it mean!
lip277
Seattle
Welcome to the Group!
As far as the transmission goes...
The getrag 265 shares parts of it's casing with the 262 transmission and thus has the same 262 casting numbers on it, hence the possible confusion.
As long as you are confident on the transmission otherwise - should be good to go.
As was mentioned earlier - there is the need for the mechanical speedo drive at the rear of the unit .... and other things for a 4 to 5 speed conversion.
This is a good write up to start your journey-
http://www.cscoupe.org/tech/5speed.html
bmwe91974
Copenhagen
ok many thanks for your support .it is quite clear with the mummer.
But the man whom I bought a gearbox, said that there is a mechanical speedo on the gearbox. If I understand it right then it is the hule as pages on the left side obliquely wheat end where Axel is put to.:oops:
I'm not so keen for it now:?
bmwe91974
Copenhagen
I just got my eye on something.
In my city!!
