Mounting CSL Arches
'69 2800cs
Moorestown NJ
I have a set of CSL arches I am mounting on my 2800cs and they did not come with rubber or screws.
Rubber appears to be available but the screws are on backorder.
Does anyone have pictures or details of 07119907707? It's listed as a fillister head self tapping screw, ST2, 9x9,5.
I'd be happy with a substitute if I knew a little more about what I am looking for.
thanks,
30csl
London/Herts
I just ordered some small stainless sell tappers. Ideally you want to remove them every few years to clean and waxoyl behind them so avoid rivets as often used! Just order a set of about 50 small self tappers - from memory you need about 8 per wheel arch. Key is for them not to be too long - i'd say about 10 mm thread length. Make sure you have a small drill bit to drill a starter hole for them.
'69 2800cs
Moorestown NJ
I ordered 54129734126 "synthetic strip"...I've yet to receive them however.
Thanks for the tips on mounting. The ST2 9x9.5 probably tells me everything I need to know to buy them from another source.
'69 2800cs
Moorestown NJ
I cancelled the order for the rubber strip, it seemed I would never get it.
I emailed CSI and Ben suggested using the part he lists as 411A on his site, which I think corresponds to the same 54129734126.
Here are the pics...I'll figure out the screws at some point!
