LAN e9 empresas y tribulaciones, an epiphany in 042BBlau. Opus Magna
deQuincey
Quousque tandem...?
rubber plastic corners glued using cyano gel
best way to avoid defects is to glue only in the inner side
deQuincey
Quousque tandem...?
the bumpers job...continuation
using 4mm SS rivets
mark the position of the holes, and make the first one, start center and move towards ends
mark, punch, and drill
adapt the shape
and fix with rivets
deQuincey
Quousque tandem...?
A way of solving the concern about the replacement of sound deadening pads
once you consider a repaint,these pads might be an obstacle your first thougth might be to put them as the factory did, glue them to the body-in-white and then spray the paint over them, but this will create the same problem as the one we know our karman product has
the other option is not to install them
a third possible option is to paint two times, first paint the body to ensure the rust proofing of the sheet metal, and then paint the pads themselves
here we go:
and then separately paint the sound deadeners
finally place the sound deadeners on top
for the records: scale of temps:
and reality:
Many
a good session of brake bleeding: for a second time, as first did not get to brake too well
also bleed the clutch
deQuincey
Quousque tandem...?
epitafio:
punto y final. como decia aquel "perseverando en el error hasta el desastre final"
ese momento ha llegado
bebemos el amargo caliz de la suspension de toda accion; brazos, manos, pies caidos, los ojos entornados y la boca cerrada
la "opus" esta completa, pero solo visible para los camaradas, para la tripulacion de esta yola de crucero en la que Marlowe comienza su narracion de tinieblas mientras se le escurre la marea en Gravesend y el tiempo se hace eterno. No completa como un huevo perfecto, sino como el laberinto de arena de Borges, como la circunnavegacion fatigosa del gaviero Maqroll, como el bel-arte del asesinato de Thomas mi alter ego,...porque "If once a man indulges himself in murder,..."
a nueve de agosto de dosmilveintitres. anno domini​
deQuincey
Quousque tandem...?
epilogue....
the e9 works can hold for a while, meanwhile enjoying Mutis and his homonym novel to my opus magna thread...
...the ways of the Lord...
  • Sad
Reactions: Dlc
