Help - Trying to Identify an M30 Motor
bmwmadman
Escondido, CA (near San Diego)
I need some help. I'm trying to find out what year and make this M30 motor came out of. The vin # 41584218 below the vin is has another set of numbers as follows # 34 6K B.
Does anyone know? Is this late of early? Thanks for the help..
Gary
Mario L.
Bedford, NH 03110
This number makes no sense to me offhand
Is this a carburated engine, or injected . .
What does the engine have for large numbers on the block, below cylinders 2-3 on the left side.
There should be a 3.0 3.3 or 3.5 in the casting
What number are on the cylinderhead for production dates?
Not all the stamped in numbers on the flat surface above the starter match chassis serial numbers.
Mario L.
bmwmadman
Thanks for responding. 90 for a 7 1 is stamped in the head. So I guess its a late model...
Its also an injected motor
I don't see the 3.0 or 3.5 in the casting. I was told it was a 3.5
velocewest
Columbia Gorge, US
The VIN is stamped on a flat at the rear of the engine directly next to the starter. It will be 7 digits, no more, no less.
Heads get swapped with regularity, you'll learn next to nothing of value about the engine from the markings on the head.
If you look on the intake side of the block, below the carbs, there will be numbers cast on the block, about 2.5 inches tall. If you cannot find them, the engine is an early 2.8.
mbmw
Cavan, ON
34 6K B should be :
34 displacement
6 cylinders
K Catalytic
Could be any of the following:
346KB 01 A 635KAT/1 A 11 00 1717252 M30 B34
346KB 02 A 635K/1 UJ A 11 00 1717485 M30 B34
346KB 03 A 735 32 KAT A 11 00 1730818 M30 B34
346KB 04 A 303501 A 11 00 1730849 M30 B34
346KB 05 A 735 32 US A 11 00 1730812 E M30 B34
  • engine.pdf
BBOY
Thanks in advance. Is there site where I can identify this motor. 20200410_172959.jpg20200410_173004.jpg20200410_173012.jpg
