Help identifying relay
sidcc
Arizona, USA
Can anyone help identify this relay, located in the top corner to the left the fuse box?
Many thanks
Sid
Sent from my iPad using Tapatalk
How bout a pic of the base showing position and number of pins.
jmackro
San Juan Capistrano, Ca.
I think that's the "load shedding" relay. It's kind of important; pretty much all the car's electrical devices are switched through it, taking the load off the ignition switch contacts. It also shuts off power-consuming devices while the starter is running.
sidcc
Arizona, USA
Here is a pic of the base. Three pins are marked 85 86 87 and the vertical one is marked 30/51. The face is marked Hella 91/6-21-12V.
Many thanks
Sid
sidcc
Arizona, USA
Great! Thank you.
Note that the load shedding relay as Jay identified it has much larger spade connectors than normal for pin 87 and 30
