Bringing a '74 back up to her intended glory.
Stan
Newmarket, New Hampshire
Bmachine
Northern California coast
Day two of old motor disassembly. My buddies John and Gavin came over for some serious help and serious beer. The head is now going to be cleaned and ready for a new home. I will keep the block because it is the matching number to the car.
EC89B6F1-6F96-44AF-A4E6-7505422C5084.jpeg A6DBE27C-A32E-4808-B91F-C2F6CB11BD1A.jpeg
Bmachine
I really wanted to finish installing that AC condenser and fan. To attach to the body I thought I’d be smart and cut off the tabs from the old one and rework them to fit on the new one.
I’m not sure it was such a smart idea because it took a lot of work to make them fit with this wider condenser. And then cleaning them up and removing all the grime and rust was extra time consuming.
Once they were cleaned I powder coated them as well as the brackets to attach the fan (along with some sway bar parts) and finally installed them with stainless bolts.
And with an impeccable sense of timing, the UPS man brought over a shiny new baby in a cardboard manger.
9449D93B-47CD-4FE4-BCF3-4A8756ECFFDE.jpeg BFA27715-448B-49D4-9447-462911B81866.jpeg D4A3CD26-80B8-4CFF-B8BF-1D63B104D418.jpeg DEDDC8EF-7FBC-4368-BE1D-9BA2274758AC.jpeg 3C63CC6D-A10D-4EBA-A642-CA20315D8607.jpeg 0D8B6F2B-6622-4859-8122-2AA37C18D290.jpeg
Bmachine
Weekend report. First, Gavin and I spent a stupid amount of time trying to figure out how to separate a rusty euro 635 bumper from its spoiler. There is no delicate way to do this other than using cutting wheels, hammer and sacrificial parts. This is so I can modify the spoiler for my car as demonstrated by Paul Cain. This is not an easy prospect so it will be for sometime in the future.
F97B06A6-BEEC-431D-B737-649124E5EA0D.jpeg 30643A2D-D135-4CF9-9864-8279879698A3.jpeg DCE58060-EAD5-475B-870F-18CEAC1CE2A7.jpeg
Bmachine
Second was re-installing the brakes. As always, once you start on a section, you have all the major parts ready and then you find out the little parts are either nowhere to be found or really old and crappy looking so you end up spending a ton of time cleaning or restoring. And if you can't find them you have to order them which sets everything back a week. So I powder coated the clips and had enough to put most of the system back in place. Rebuilt calipers, new disks, fresh pads, steel braided hoses. I also sanded and repainted the brake booster extension going into the firewall.
D348B755-25C9-4136-BEF6-0E0EA6EC5565.jpeg E7FB7A54-12A5-4F8E-A0EB-16586EB47C97.jpeg 4EFF3114-33FD-4EDD-AF4B-1003339F12D3.jpeg DDAB9524-3AD2-4EC8-8FD1-5D8D0A14D2F9.jpeg
Bmachine
Since I had the powder coating system all set up, I decided to try Eastwood's "Extreme chrome". As the name implies, this is their powder that approximate chrome. I have to say it comes out pretty decent for a non pro system.
One thing I learned is that with a high gloss finish like chrome, preparation is FAR more critical than on a hidden satin black part. So even though I had sandblasted those headlight rings and cleaned them with acetone afterwards, I should have baked them in the oven for 15 or 20 minutes in order to get rid of any outgassing. Live and learn...
Bmachine
Another crazy busy weekend with non car related stuff. All I could find time for was lots of parts refurbishing, and small rebuilding steps.
I recycled and cut up one of the auto tranny parts to make a bracket to hold the e36 power block I wanted to use since my battery was moved under the rear seat. I reused an existing hole to secure it in place. I also cleaned the wiring harness and started to install small bits like brake fluid reservoir, etc..
94FC39F0-DBC3-4C27-B598-81EA4ED2B89C.jpeg 83179650-75AD-4855-8DC1-165BF6B085EB.jpeg DA86319F-C6D0-45E7-8234-A07E8601C6F6.jpeg 8CE88C7E-4453-456C-9F3C-EBCC94E1A5DD.jpeg
Bmachine
After waiting for more than a week, I finally got the correct "speed nuts" to secure the radiator bracket to the firewall. That one was also powder coated and I was finally able to install the "Don Lawrence special" radiator in the car.
CDA73BE8-B8C9-417B-9A92-1A5D6F1932E6.jpeg F6B9BADF-B614-4F96-B6AC-A1A617AE657C.jpeg
Bmachine
Lots of smaller steps next:
- Re-wrapping the wiring loom
- Refinishing the plate around the inlet and outlet for the heater water and cutting a new foam gasket
- Installing the transmission tunnel heat shield (thank you Gavin!)
- Installing new engine heat insulation
- Brake lines
- Brake fluid reservoir
- Brake booster
- New brake master cylinder
47E29A9C-86AE-47DA-85A4-DCEFFE4B8DA6.jpeg 20BB0630-D615-4113-82C4-0CBCAFCED68F.jpeg 7FDCD8A8-8B34-4104-BB0F-4A4427A8BCD0.jpeg 1536B2E8-C89A-4FC6-9746-D6EDDB1E226D.jpeg FA6A0AF3-EBB7-49D0-B038-34712990A820.jpeg 3277CD74-F203-4D3B-A680-1B70C947FDF3.jpeg 620D0C25-EE7D-48D2-A765-5A6D935320C8.jpeg 6C493280-4D62-4A60-86C2-48DB8A71F4F9.jpeg AD143F9E-94C4-4C38-9073-2185E80D196E.jpeg 5923D3F8-56AA-4BE4-89EE-B2D8D78C1A10.jpeg
Bmachine
I always like moving the battery under the rear seat. Ive done it on all my Tii's and my first coupe. More room in the front, no room lost in the trunk, and with the newer smaller batteries like the Odyssey it works perfect on the coupe.
- Cut some 4AWG wire and run it through the frame cross member. Crimp new lugs on it.
- Cut a steel band that will be used to secure the battery.
- Using an old e30 brake boot, I cut a rubber protective strip to protect the top of the battery.
- Finally install a kill switch.
6781E4F8-86E0-4E06-BF42-A8AB430EBDB6.jpeg 7952CB2F-0B86-4B38-85DC-55DE81707426.jpeg 75E2A119-09DA-4304-94D8-41C4EAD2DF08.jpeg C9AC4E71-F672-4849-A7C6-CB44969EF77B.jpeg
Markos
Seattle, WA
Your thread keeps getting better. More pics and detail the “chrome” please!
Bmachine
I think I speak for most who are deep into restoring when I say that the support shown by you guys for those who are going through it is an outstanding motivator! Especially when you feel like every little step is fraught with unexpected problems, new questions, missing parts/tools and never ending budget and schedule overruns.
Thank you!
Bmachine
Two more pics of the battery relocation. One interesting thing is that I found a "grommet" that perfectly fits the opening in the driver side floor. The weird thing is that I have no idea where it came from! I still have to find a way to make it stay there (right now it just drops in there) but I can't believe how well it fits. One of those rare strokes of luck where you need a very specific item and it magically appears on your work bench....
EDIT: Asking my buddy Gavin, it appears that it might have been something "we created using a plug and a round grommet I had" a year or more ago.
A4EE1CD6-648B-46C0-8A68-68E78127DF8D.jpeg 83E5A2EC-A44E-4A08-88CE-9FFCCF9D601A.jpeg
Bmachine
Ok, I've been put out of commission for more than a month due to a small accident while working in the engine bay. Details elsewhere.
But just to update this thread, I was fortunate enough to have been pretty close to done with my part of the job when this most unpleasant mishap occurred. With the help of my buddy John and neighbor Ron, we re-installed the front bumper and for the first time in nearly two years, the coupe was back on its four feet.
E85E1DB4-95B8-478D-BA88-7B9AA8B0BF3A.jpeg 333E9C7E-A8A7-4F02-BC2A-531834850B50.jpeg
Bmachine
I had always decided that, while I would do most of the non critical stuff myself, rebuilding and installing the motor and tranny would be something I would have my buddy Carl at La Jolla take care of. These are the things I wanted to have done right the first time. With that also comes the peace of mind that the beating heart of the car will be trustworthy for years to come.
So the following week, this was the scene in front of our house... San Diego bound!
