god knows why I am using this thread to ask questions..., well probably someone else knows why too
the fact is that i would like to understand this rewiring issue a little bit
so i can see that the lowbeam wiring goes straight from the switches in the dash and column to the bulb, without any relay, right ?
steve is adding a relay for the lowbeam, but it is not strictly necessary, and only the addition of the highbeam lights to the lowbeam ones means the need of a relay to support 4 H1 lights electric consum
well, as you probably have guessed, I would like to add two additional lights to my standard setup, but my intention is to use them independently, not necessarily together with the high beam
i will use a relay to operate them and a switch in the lower dashboard to turn them on or off
so, from where do you recommend me to tale the signal (+) ? from the main lights switch in the left side of the dashboard ?
