CSL Alpina Steering Wheel
tferrer
San Francisco, CA
You might appreciate this @CSL177 Pic from yesterday, driving down the coast after a spirited 75 mile rip through back roads. Put the CSL Alpina on. So much better than the Petri.
Drew Gregg
Ft. Lauderdale
Russ, @CSL177, had a birthday yesterday,Sept.11th. So what better car to drive to a BMW Cars & coffee than his fully restored '67 911S ??
CSL177
Lake Worth Beach, Florida
@tferrer I shoulda kept that wheel... hey, since it's not period correct for the car, wanna sell it back to me? ;)
Thanks again for the invite, Drew. Your coupe is extraordinary, the best car of the gathering.
CSL177
Once again Drew, that color is just amazing... and a lot of subtle personal touches that are just right make the car. You did good.
tferrer
San Francisco, CA
Russ, the wheel you had put on wasn't a CSL Alpina. It was a very early (and very nice) 360mm Alpina, whereas the CSL Alpinas are 380mm and have that unique kinda droopy spoke configuration. I ended up trading it (plus dinero) towards the correct CSL specific Alpina you see in that pic above. That 360 Alpina would actually be great in your 67 S. I think @JohnP_02 might still have it in his collection if you want to wheel and deal to get it back!
Gary Waggoner
San Clemente
Gary, my car wants to look like yours when it grows up.
What springs did you use to get that drop?
Thanks in advance.
RP
I have Carls springs front and rear. I dont understand why your car is so tall in comparison.
Patton
Atlanta GA
Did you re-drill the body and put the trim back on? It looks way better with the trim in my opinion.
Gary, the Nelson’s didn’t work for me, as evidenced by the photograph.
I agree, a lot better with the trim.Thank you. Believe it or not the 3M double stick tape is doing a nice job.
Looking back at the photographs, I’ve got some work to do on the fiberglassrear bumper.
Also looking back on some of the old photographs, the door has now been lined up and the trim line, with the flexibility of the double stick tape, is nice and straight.
My thanks to everyone for your inspiration and support of the project.
Patton
Atlanta GA
Thank you. Gary is your stripe a decal or paint?
Here is a photograph after some ceramic coating stuff
tferrer
San Francisco, CA
Looks planted, Tyson... is that after the springs were swapped?
Yea, Russ - H&R progressives and Spax adjustable. Rides SOOO much better. Now there's actual compliance in the suspension. Now looking at the sway bars you put on. They are quite large! I would venture a guess that my back roads don't quite need the same as turn 17 at Sebring ;-)
tferrer
San Francisco, CA
Couple more from the L and couple weeks back. There is a monthly drive called the Breakfast Club Rally and if you get stuck in with a good group, then it's a blast. If you get stuck behind a guy in a McLaren 720 driving 12 mph it's not...
tferrer
San Francisco, CA
Glad to see you got on the BCR, @tferrer . I've been doing it since it started last year. I've been sidelined for a few months due to car repaint though.
Yea, I've gone to a few of them starting when they first kicked off but my initial experience wasn't so great as the roads were abusive.
Let me know when you get your ride back together and we can connect for one of them!
Wladek
Gdansk, POLAND
You might appreciate this @CSL177 Pic from yesterday, driving down the coast after a spirited 75 mile rip through back roads. Put the CSL Alpina on. So much better than the Petri. View attachment 126507
So all was correct - you need momo horn button with metal silver ring & "glossy flat black" plastic frame. Both Alpina & BMW had them.
That one you have look like repro.
tferrer
San Francisco, CA
Thanks Wladek - yes, it's a reproduction but I have an original Alpina horn button that I'll be using eventually ...
coupedegrace
Portland, Oregon
What springs and shocks were you running prior to the swap?
For some unknown reason the PO of my coupe had installed massive sway bars front and back. Not sure of diameter, but the front one was so thick it actually damaged the mounting bracket on the drivers side. I say unknown reason because as far as I know (and can tell) the car wasn't tracked or autocrossed or anything like that.
-Dan
CSL177
Hi Dan, I ran cut springs and Bilstein HDs with big bars (29 & 24mm w/hard bushings IIRC) but it was used as a track car. Not much suspension compliance,
and it cornered flat. Front camber plates were fixed at -1.5 degrees. I'm sure it's MUCH more comfortable to drive the way Tyson has it set up. Looks good, too! ;)
