Need a rear license plate holder for 71 2800CS. Please send PM or email [email protected] if you have one or know where I can buy one.
The Tee brackets do not reach the center hole as the top of the Tee's attach to the license plate. The Tee's in the pic I posted are backwards and mounts on the outer bolts.2800CS originally used an H shaped holder with a single center mounted bolt to the tail panel. I just saw one recently, can’t remember where. The T shaped ones mount outboard of the plate, don’t know if they will reach the center hole though.
Someone drilled your panel, get the CK bracket and use the center mounting hole.I’ll attach a picture. Looks like previous owner may have drilled holes or should I see two holes like these.
