Simufly
Going through the accumulated stuff. Come across this upgrade kit. The write up can be found on the forum
$25.00 plus shipping
Appreciate the response, thank youProvisionally sold
YepDo these work with both e3 and e9???
I bought the handbrake upgrade kit from Coupe King. I believe it was called the Paul Cain. The restoration shop installed it and my brake has worked fine without the sloppy lateral movement it had before the work was done. I guess this is even an additional upgrade?
$25.00 plus shippingView attachment 82228
LOL, the sad part is, I believe you.I’m working on an even better solution. An M10 bolt with a steel sleeve. A brass bushing floats on top of the steel sleeve. The bushing has a zerk fitting, and the kit comes with a grease gun loaded with graphite grease. I am using swiss bearings imported, stress tested, and branded by Powell-Peralta.
You can finally achieve Ronin-Style e-brake turns on the streets of Paris without dislocating your shoulder (again). If you want the best of the best of the best, go with the @Markos kit! Diagram that highlights the inferior design of my predecessors is in the works.
No sadly it has gone. There are several other upgrade around. The DeQ version would seem to be top of the pops ATMSimon, do you still have this for sale?
if not can you tell me where I can buy it (as you know the handbrake on NEW needa some work).
thanks, Michael.
