chope97
will a European gasket for a 74 E3 fit an American market 73 e3? What trim will fit? Thank you
perfect info.Any gasket will fit, but the 73 and earlier has different lower trim, 74 uses a larger lower trim. You need to match the correct trim to the correct seal. You can’t use 73 trim in a 74 seal.
its the same part number. should work fineI have a 74 parts car with a good gasket and trim so I could use that trim on the 74 euro gasket?
