SicilianE9
I have been looking for cross drilled discs , any idea where i could find them?
Thanks in advance
Best regards
Luc
Thanks in advance
Best regards
Luc
Thanks for your reply Chris,
I am not impressed by the standard E9 brakes and I have experienced a gain in braking performance on my other cars by adopting cross drilled brakes.
It is also the only tolerated change by the german TÜV if you want to keep the historical plates.
I will be participating in quite a few alpine rallies and some of them in winter.
Cross drilled discs not only improve Heat dissipation but also prevent that water gets trapped between disc and pads delaying braking.
Being a reversible alteration,i will accept the esthetical divergency.
Best regards
Luc
i asked a similar question to a noted east coast USA performance and restoration expert - familiar with e9 coupe cs / csl as well as racing e30 M3, etc. his comment was that the most important thing to improve e9 braking was to replace all of the bushings to urethane or solid - depending on your comfort tolerance. he advised this over increasing disk size / bigger calipers.
Sounds like the TUV is tougher than even the MOT for the Brits?
Best regards Luc
I’m feeling a bit stupid on this one :confused::confused::confused:. What are or where are these magic bushings that make the brakes work much better ? THANKS ~ John Buchtenkirch
