Ride height/stance actual measurements with photos
Bmachine
Northern California coast
There are lots of discussions about ride height but I have found very few actual numbers tied to corresponding photos to quantify that. Things like "Springs from XYZ lower the ride height by x inches/mm" don't mean much since they don't say relative to what. (Compared to 50 year old original springs with varying degrees of sagging?)
It would be useful to compile a list of the measurement from the floor to the top of wheel arch with matching photo for as many setups as possible. Then indicate what springs, tire size and inflation, plus rear spacer thickness since they all impact ride height. Various iterations of the Carl Nelson springs have been used, stock springs, coil overs, H&B, and I am really interested in the looks and measurements of the Paul Baker springs which look really good in the thread below. I know @HB Chris has installed them so if you could post pics and numbers, that would be awesome
The goal would be to have a repository where anyone could go and say "If I use these springs with these wheel and tires, this is approximately what the stance/ride height will look like"
Bmachine
One post I found was from 2013 where @deQuincey posted these numbers:
ALL DIMENSIONS IN (mm)
...............................LEFT SIDE: ..............RIGHT SIDE:
GAP FRONT ...................35 ..........................35
GAP REAR .....................32 ..........................35
FLOOR FRONT ...............275 .........................280
FLOOR REAR .................300 .........................300
WHEEL CENTRE FRONT ...350 .........................352
WHEEL CENTRE REAR .....347 .........................350
(EDIT: my original totals below where wrong because I misread where the Floor measurement was ending in the above photo. Here are the correct numbers. Thank you DQ!)
Which gives a floor to wheel arch measure of 665mm / 26.2in front and 662mm / 26.0in rear
He said in that post that he was using the CN springs at the time.
Bmachine
Mine is using Hardy and Beck springs in the rear and B&G in the front.
Tires are all 215/55/16.
Inflation is 35psi front, 32 psi rear
Rear spacers are W&N 2 dots
Measurements are 664mm / 26.14in front
and 635mm / 25in rear
Bmachine
Good point @boonies. Thank you for that link. I am hoping to build on that excellent spreadsheet idea to include photos which illustrate what those numbers actually result in, as well as to include numbers for the rear setup. I also want to include name/brand for the springs so people know what each of them does. Paul also says he was looking for data "on stock front springs originally fitted to the E9 Coupes" while this would be for any of the currently available alternatives.
deQuincey
Quousque tandem...?
deQuincey
Quousque tandem...?
Which gives a floor to wheel arch measure of 650mm / 25.6in front and 647mm / 25.4in rear
you took a bad reference, because my floor measurement is from floor to body panel not to wheel centre,
so to compare with your dimension you must do the following :
FRONT
350-35= 315, this is wheel radius
and now 315+350 = 665mm same as yours
REAR
347-32=315 well done !
now 347+315= 662mm, higher than yours, but my spacers rear are the thick ones
Bmachine
FRONT
REAR
OK, it took me a while to understand this. Because the picture is dark and that Photobucket graphic is in the way, it looked like your Floor measurement was going to wheel center. But now I see what you are saying! It is only going to body panel. Thank you for clarifying!
That is why I like a simple measurement from floor to wheel arch. There is no ambiguity or calculation needed there. And, when we judge the stance of a car that is really the simplest way to put a number to that visual quality
One additional variable that should be mentioned is, as you pointed out, which rear spacers are used. I will add that to the original post
HB Chris
Huntington Beach, CA
Pirelli 205/70-14 tires, PBCM lowering springs, three dot rear pad (required!)
24 3/4” front, 24” rear measured from floor to arch
Bmachine
Nice Chris!!! Those are really good numbers. They seem to match the photos posted by Paul Baker in the link above very nicely. Do you have a profile shot of your car by any chance?
