Rear brakes over-heating, possibly fading on 3.0CS
taylorcom
SF Bay Area
I always use compressed air and never had a problem with it. Just exercise common sense: block of wood in the caliper to prevent a piston from flying out and hitting the other side, small clamp to restrain pistons that you don’t want to come out, wrap the whole assembly in an old towel to keep droplets of brake fluid spraying everywhere when a piston pops out.
Assembly: I have always used Castrol red rubber grease, but any grease compatible with DOT 3/4 should be ok (Miller’s, Rtc). This type of grease makes assembly a bit easier and doesn’t absorb water so it may help delay rust formation on the bores and pistons.
John
I don't have an air compressor, but I did once own a '64 Julietta.
Redrumm3
Tampa, FL
Are you taking into account the chamfered edge? It looked straight to me.
It could be straight but in the image it looks a little crooked to me. Did you clean the bore and piston before trying to reinstall the piston? Was there any scoring, rust or marks on the piston or bore? If so, you need to clean them up. I use steel wool and Brakleen to remove any deposits. Lightly polish the piston until clean. Is the seal seated all the way into the groove? I can't speak to the Centric seal kit, but some seals have a chamfered inside edge and if installed backwards it makes it very difficult if not impossible to reinstall the piston. Look at the inside edge of the seal and see if there is any chamfering on the inside lip. It looks to me like the piston is hanging up on the seal, FWIW.
Arde
Cupertino, CA
Interesting thread. I cannot be of much help, I just wanted to say that I like the word chamfered and as soon as I learn what it means I will add it to my lexicon. Good luck with the brake system, I know Don worked some magic on mine and now it brakes better than a modern car.
Redrumm3
Tampa, FL
Similar to a beveled edge.
sfdon
sfbay area
You used a prybar to install a brake piston that normally takes finger pressure to install?
Why?
taylorcom
SF Bay Area
I've R'd and R'd the piston since that pic was taken. I saw no scoring but did see some rust smears, not pitting, on the piston, which I cleaned off with steel wool. Yes, the new seal is seated all the way into the groove. There's no champher or bevel on either seal, though the new seal is a tad taller than the old one (which might be a result of 50 years of wear). The old seal has a thin lip that extends on both sides of its inner edge, which the new seal doesn't have. The new seal also seems a bit thinner than the old one.
taylorcom
SF Bay Area
Why?
Fingers didn't work. In fact, I've never known fingers to be strong enough to retract a piston during a brake pad change. I've always had to use a stout screwdriver as a pry bar for that. This time, I used a real pry bar.
Have you used the Centric rebuild kit? The new seal is a bit taller that the old one, which may be a reason for the hang up.
Redrumm3
Tampa, FL
With the caliper removed from the car and the bleeder open you should be able to slide the piston back into the bore with your hand/fingers as @sfdon said. The piston needs to be perfectly aligned with the bore to make this happen.
taylorcom
SF Bay Area
Fingers got the piston started, but then it seemed to hang up on the new, thicker seal. A C-clamp, which Dick recommends, got it further in. Then it was pry bar time. Eventually it seemed easier to move, so I've probably pushed the piston past the new seal.
TedS
SoCal
IE’s customer service is very spotty and you have to send yours in, just noting as something to consider.
I've not had any issues with them personally and I've bought a few things from them. The link is more of a suggestion that one can get these rebuilt professionally without having to wait for Napa to restock rebuilt ones. I'm sure there's a place in the Bay Area.
OCCoupe
Monterey, California
I hear that Centric has offered rebuilt units, but has no cores at the moment.
Napa gets their e9 calipers from Centric. Unfortunately that means that Napa does not have any for sale. If you call joke local Napa store I’m sure they will tell you that they are not currently available.
mulberryworks
Mr. Fixity
Jacksonville FL
I've got the caliper off the car and have replaced the inner seal on one of the pistons. But I'm having trouble getting the piston back into the caliper. It doesn't want to go further than you see in the pic. Is this normal? I lubricated everything with brake fluid, but still no go. What's the protocol for getting it back in place? The pic below shows the rebuilt piston on top, old stuck piston below it:
Red Rubber Grease is a good lubricant for reassembling hydraulic parts, that's what it's made for. Castrol and others make it.
JFENG
Bahston (Boston)
I still use Castrol red rubber greaseThe smallest tub of Castrol should last a Lifetime for a shade tree mechanic. I think the heavy consistency does a better job protecting the rubber components during assembly (esp. for delicate wheel cylinder seals on drum brakes) . Plus it doesn’t absorb water so I (irrationally?) feel better about using it to coat a ferrous steel caliper piston and bore. Yes I know it’s all sealed up under the dust cap, but it still bugs me to use BF outside of a closed system.
Friends who are better mechanics recommend synthetic grease for brake assembly. One swears by Sylglyde (silicon) because he has DOT5 in all his classic cars,and another loves this ATE stuff because German cars deserve German lubricants (talk about irrational).
The brake cylinder paste is used for the repair, assembly and corrosion preservation of internal brake components. Its lubricity also enhances ease of fitting, especially of rubber parts on metal surfaces.
The brake cylinder paste is not splashwaterproof. Its use is there fore restricted to internal surfaces in protected or sealed installa tion positions.
The brake cylinder paste is used for hydraulic brake systems designed for operation with brake fluid based on polyglycol ethers according to the standards FMVSS 116 (DOT 3, DOT 4, DOT 5.1), SAE J1703 and DIN ISO 4925. It is not planned for usage in brake systems with a silicone or mineral oil based hydraulic fluid.
taylorcom
SF Bay Area
Thanks, Mulberryworks and Jfeng. Yeah, it may need more lubrication than just the brake fluid. I experimented by removing the new inner seal and putting the old seal back in, and it was just as hard to seat the piston into the bore as it was w. the new seal.
