None of the components you listed are mentioned in the "blue books" via a vis assembly torques. If you are fastening steel components, I'd say you could comfortably use a standard fastener spec table. Where aluminum components are involved, I'd use the lower strength alloy torques from the chart so as not to deform the thermostat housing flange.
