if you don’t hear injectors clicking on one bank and you do on the other bank and you have installed new trigger points- you would concentrate on electrical.
were plugs wet or dry?
sf - plugs were dry. Yes thanks on the TPS/injector firing test, I have checked this many times, there is a muted clicking, my screwdriver handle to ear test on each individual injector tends to make me that not all are firing as you open throttle. But definitely not a "Bbrrrpp' more of a clicking. You mentioned banks of injectors. I cannot find anywhere on jetronic.org or otherswise how the ECU fires the injectors (what sequence) just that there are 2 driver circuits in the ECU, implying that the ECU fires the injectors in 2 banks of 3 each. Do you know which injectors are fired together ( ie is it 1,3,5 followed by 2, 4 ,6, prob different given cyl firing order)if you don’t hear injectors clicking on one bank and you do on the other bank and you have installed new trigger points- you would concentrate on electrical.
Dana: progress, the ECU is working! Now the unbearable wait for SF Don’s points
Is it true that when engine braking the injectors are fully closed? Not even idle type of fuel delivery?“
Additional acceleration fuel pulses generation by the TPS can be checked as follows: Ignition ON, motor NOT running. Slowly by hand open the throttle valve. During opening you should hear the injectors open shortly about 20 times (sounds like a kind of “Bbbrrrrrppppp”.....). When closing the throttle valve you should NOT hear the injectors work !”
not trueIs it true that when engine braking the injectors are fully closed? Not even idle type of fuel delivery?
So Don’s MPS worked? But yours doesn’t?Bill - Halleluiah !!! And my problem seems to have yielded to replacing trigger points and MPS both !!
We are both in the clear and happy motoring awaits in 2023, most excellent
Stay in touch
Dana and Astrid
Bill - Sfdon saved the day and I am sure many hours of testing what I believe are essentiall OK wires, grounds, even injectors etc etc. When I substituted Don's ECU, there was no joy. I moved on to the trigger contacts and mine were quite worn so I substituted Don's. Meanwhile I put my ECU in so that only one variable was changing. At that point, only a 5 second start. I then substitutrf Don's MPS and voila, perfect start and running immediately. Today I changed my points, reset the dwell, car ran real nice. I attempted a timing check but could not find the flywheel marks through the clutch housing window, so for now I had to abandon that. I did not try putting my worn trigger points back with Don's MPS in service, but what I know for sure is that my MPS is bad ( despite testing OK !!) and the trigger contacts are very worn.So Don’s MPS worked? But yours doesn’t?
When I replaced the points in my stock 2800CS engine with a Pertronix, the car went from barely running with a sputtering idle that would die as soon as the throttle was touched to running well enough to drive on the street and idle well. So, bad points. But even as it ran successfully, there was an occasional backfire thorough the front carb. It didn't seem to matter what the engine speed or load was. It would happen once every few minutes or so. I tried to set the timing with a timing light, but even after painting white the spot on the flywheel that you should be able to see in the window, the spot would only appear randomly at lengthy intervals. Clearly the timing is varying wildly, even with the Pertronix installed.Today I changed my points, reset the dwell, car ran real nice. I attempted a timing check but could not find the flywheel marks through the clutch housing window, so for now I had to abandon that.
Bill - yes. Despite good ohm readings across both sets of pins and a solid vacuum test - held 15 psi vacuum for 5 + min. Go figure !!So Don’s MPS worked? But yours doesn’t?
kudos to our e9 forum member who first suggested the “e9 lending library”
He knows about this.
We all thank him.
