Apparently complete assembly required but not entirely sure. It is screwing up all of my lights as apparently they all go through this
Need new hazard button urgently. Best source?
That is the exact problem we are having. It does not stay in when pushed in. What is the fix? Can I call you?6 or 8-pin? I imagine. Part number on it also tells what it is.
Screwing up lights? How so?
Usual issue on these is that they don't stay in when pushed (i.e. turned off). Easy fix actually.
all good. Carl Nelson is taking care of me. He rocks.Yeah, I did the fix on mine and it failed again soon thereafter. Old plastic is very hard to repair reliably and this switch is crucial to have working properly because of all the connections that pass through it. The bummer is it can pop out at any time, putting the flashers on and killing your battery. It's bad when a failure mode can cause other things to go off track.
New ones aren't that hard to find but you need to make sure you get the right number of pins.
www.getbmwparts.com shows the 6 pin in stock.
Ebay sellers have both the 6 pin (61311355358) and 8 pin (61311356193) versions.
Search for
New BMW Hazard Flasher Switch 6-prong
or
New BMW Hazard Flasher Switch 8-prong
or some variation on that and you should get plenty of results.
