M30 engines, parts...FS
Bavman
I have a bunch of M30 engines and parts...Just got a strange one in yesterday, 1982 casting head with mech fuel pump hole, has 4 bbl carb/manifold and then on the other side thermal reactors...all this in a 1978 633CSi, can't tell what the bottom end is but has bottom bolt oil canister so probably e3/9 engine transplanted....Will try to get some #'s off the block $400 for complete motor, has been sitting a while.
Motronic 1985-87 heads, Complete $200 ea
Motronic Big Valve 87 up heads $250 ea
M90 bottom end, has been sitting forever $500
M106 bottom end also has been sitting forever, was told 18k original miles #6 got some moisture in it in storage...think block would need to be bored..$400
2.8 Euro L Jet motors, have 2 $400 each
3.2? Euro Motronic $400
2800CS carbed motor $400
3.5 Big Valve 1988 in car and running $600
3.5 Big Valve 1988 6 series, tested, with 6 series harness $700
All this stuff is located VIR/NC 27305
Email is best way to reach me [email protected]
Markos
Seattle, WA
Al,
Check
In my opinion that head is worth at least $300 if it still has the material on it. It has the mechanical fuel pump hole plus the new water ports. That means it is a good option for someone who blows their original with the bean water ports. The only alternative is to switch to an electric fuel pump, and not everyone wishes to deviate from stock.
Also, can you post the VIN of the 2800CS motor?
Bavman
Also will be heading west in Sept for the Rennsport Reunion at Laguna Seca...can bring some big heavy stuff...
Al
