Hydroboost instead of vacuum for brakes?
m5bb
Peachtree Corners, GA
Has anyone considered using a hydroboost system instead of the vacuum booster for the braking on a coupe.
I see these systems in many hot rods and they seem so simple and don't take as much space.
It uses the power steering pump to supply pressure to the booster for brake assistance.
There are many on the market in the $500 range.
Gary
J.B.
Naples FL
I had issues with getting enough vacuum when I was running triple webers. My mechanic installed a hydroboost system from a 535 that worked fine. I did have issues with the "brake bomb" leaking but I think it was due to the age of the part which was purchased used out of a wreck.
kasbatts
Auckland, New Zealand
I'm collecting the bits to do the BMW hydro boost conversion right now, will be doing this sometime next year when I do my engine swap.
As my car is a RHD there is a bit more plumbing to be done, so engine out will be much easier.
teahead
aka "Rob"
Tacoma, WA, USA
Chevy astro vans are the ticket. Now the bracket may require some fabbing up.
