Driveshaft alignment tool
Frederick
Park City,UT
Is this tool necessary or recommended?
BarneyT
Austin, Texas
It helps to align the driveshaft without the deflection of the rubber Guibo… Hal Boyles, makes a part/tool like that for 2002s
Frederick
Park City,UT
Yes, thank you. Just wasn’t sure how critical it was, although driveshaft alignment seems fairly critical. o_O
halboyles
KC
Thank you @BarneyT for mentioning us. I created this tool after hearing story after story of failures of the current versions of. the guibo, even OEM versions. This tool ensures that the front half of the drive shaft is correctly aligned with the transmission before bolting everything down, thus saving you many hours and many dollars in replacing the guibo.
Here is the web page for the tool.. On this page, you can read/download the instructions for using the tool.
Frederick
Park City,UT
Thanks Hal, indeed, I have seen a lot of concern and issues pertaining to the Guibo and their failure rate.
