Hi there
I have pulled the automatic transmission from my '73 Bavaria resto. I am going to install a G265 transmission in its place. I have measured a few things,
The length of auto trans is 590 mm
The length of G265 is 552 mm
(these measurements are from front face of bell housing to the rear face of output flange; I secured a straight edge across face of the bell housing and a straight edge across the rear face of the output flange and measured between)
Since the auto box is 38 mm longer than the G265 I am planning to have the front '1/2' of the driveshaft that came off the Bavaria lengthened (and install a fresh BMW support bearing too).
When the drive shaft is in being lengthened and rebalanced, I will have the driveline shop repair the universal joints on both halves.
Does this sound reasonable?
I plan to use a BMW Guibo that measures 30 mm thick, ~130 mm diameter, new BMW bolts/lock nuts. I have a few old ones around (out of 2002 5 spd conversions) and all of these have the same dimensions as the Guibo that was used in this automatic Bavaria. I actually can't remember ever using a 'donut' style Guibo!
Is there a Guibo that is a better choice than others, for this conversion? Part# please?
Their differences must be internal cuz several have the same physical dimensions
Regards and thx for your advice!
-Bill
-Bill
