Fuse box upgrade (prototype)
eriknetherlands
Netherlands, Eindhoven area
@Ezz
Seeing that you have some competition, I want to support your endeavors and would like to be on the list for one fusebox;
I'm not sure about which version I need, as my car is a May 73 e9 model. I have a 10 fuse version
Does your model also allow the installation of the clear plastic fuse box cover ?
Ezz
Arizona
Currently it does not. The reason is I thought of it as cosmetic and not really provide additional protection since blade fuses are not as flimsy as the original ones. However, i could be wrong. If it is something that should be incorporated, i can look into it.
eriknetherlands
It just that I like things to look original.
I would appreciate if it would fit; I'd pay extra for it.
But I know I'm preetttyy ocd-isch in that dept.
Would the fuses not be too high for the cap to fit?
  • Like
Reactions: Ezz
Ezz
Arizona
That’s still worth looking into. I will need to source a cover to make measurements and test fit.
Not sure if using the regular size fuses, but definitely will not be a problem with the low profile fuses I was originally intending to use.
