Had some spare time so wrote a list of work completed over the last 6 years.
What started with a small bubble of rust the size of your small finger nail and turned into a 6 year rebuild, Other than building my track racing saloon car, I had never done anything like this before, Am pretty proud of the final result.
Bodywork
The car was striped to a rolling shell with only the engine, head lining and dashboard remaining in the car, extensive rust repairs were then carried out, rear sills, boot floor, rear tail light panel and lower rear valance, floor sections and patches to inner sills, front sills at the intersection with the front door posts, tops of both front strut towers and inner guards under where the front guards weld on, all the usual suspects.
However, I can now hand on heart say that the car is 99.9 % rust free, and so to keep it this way for as long as possible, I have spent a lot of time applying rust prevention and cavity wax sprays.
Moving on from the rust repairs, the car was stripped to bare metal, surface treated in a heated spray booth and sealed with 3 coats of epoxy primer before the usual high build primer/sealer and base coat/clear coat paint finish in Polaris.
Complete under body, under seal as well.
Re assembly
The list of new/recond trim parts used.
New Belt line mouldings
New rain gutter mouldings
New front and rear screen mouldings
New trim to top of door windows
New trim to front edge of rear side windows
Re anodized trim to top of rear side windows
All new rubber to the entire car
New door brakes
New door latch pin plates to B pillar
All new badges
Outer door handles and trim to bottom of rear side windows re chromed
Bonnet and front fender grills rebuilt with handmade replacement fin’s, pinned and epoxied together, repainted.
Front grilles, re painted with re anodized outer trim
New Stainless steel sill mouldings (coming soon)
Interior
New “Wurth” bitumen sound deadening to floor, Dynamat to Fire wall
New carpet
Re upholstered seats (M24 Recaros to be fitted soon)
New rear parcel tray cover
Re built glove box, including recovering with vacuum formed vinyl, re flocked to inside
Recovered center console side panels with custom radio panel
Recovered panel to underside of steering column
Recovered kick panels
New door arm rest top chrome cover trims
Re chromed door arm rest posts
Re chromed inner door handles
Re surfacing of wood trim
New seat belts to all four seats
New shifter gator (hand sewn by me! very proud)
Recovered shifter surround
Recover of dash top panel
Re veneer of gauge cluster panel
Strip, clean and service of all gauges
Trunk
Re spray with Polaris over rocker/sill textured finish
New rear tail light panel (made by myself)
Re make of trunk floor panels (Made by me)
Recover floor panels, tail light panel, under side of trunk lid panels
Re cond tool tray with all new tools, lamps, fuses etc (no red screw drivers sorry
Re cond of caddy
Re cond spare wheel and new tyre
New carpet mat
Electrical
Re cond of tail lights, respray inner shells, re silvered reflectors etc
All window switches, stripped, cleaned, re assembled, 3 x new replacement
All electric windows relayed
Trunk light repair with new lens
Halogen head lamps, (relayed)
New LED glove box light (up under dash)
New wiper relay
Fuel system
Complete strip, rust repair, re paint and POR 15 fuel tank treatment
All new rubber fuel lines
New Bosch FI pump
Brakes
Complete strip and rebuild of Callipers (all new seals)
New flexible brake lines
Re cond master cylinders
New disks
Hi performance brake pads (cut from Mitsubishi Evo 9 pads)
New hand brake cables
Dot 5.1 brake fluid
Hand brake leaver pivot up grade (DQ)
Suspension
All suspension components striped and repainted
Custom HD/sport lowering springs
Adjustable Koni shocks
Custom sway bars front and rear with urethane mounts and new saddles
Custom front sway bar links
Fixed neg camber top plates
Urethane rear sub frame bushes
New diff mount
Eccentric adjusters (camber and toe) to rear arms
New CV boots
Wheels and Tyres
17 inch style 67’s on 35mm thick bolt on spacers
New 225/45/17 Michelin pilot sport 3 tyres
Drive train
Lightened fly wheel
Balanced Flywheel/clutch assembly
CR 5 speed (dogleg 1st)
3.64 LSD with extra clutch packs
New UCC shifter and DSSR
Engine
Standard 3.0 FI
K&N air filter
Custom exhaust, Magnaflow rear muffler and Flowmaster resonator
Thermal wrap to 2 x down pipes from manifolds to first collector
Pusher electric fan to Radiator
New standard radiator
