My brake master cylinder gave up the other day, like to buy a REAL good used one, rebuilt or if someone is ordering from W/N I would help with shipping cost. Thanks in advance Joe
Thanks WISE9UY, Mine is a 71 2800cs, does it work for sure?
If it works a couple of pics please, Thanks Joe
No problem WISE9UY,
Chris I am confused, what does a brake master has anything to do with the Pedal box opening? Please explain
Layne do you mean to say that the rear fluid output connection is larger? I will have to take a closer look then. The number of outputs, position, overall length and attachment appear the same.
Yes. On the 3.0cs MC, all ports are 10mm. On the 2800CS/2002tii one, the rear output is 12mm (I think) to accommodate the residual pressure valve. I imagine you could adapt it down to 10mm, but probably not the other way.
