Underpanel repair
FinnCoupe
Finland
Has anyone had same problem with dash underpanel?
Rubber/leather trim is coming loose from the steel panel.
How to fix?
Proper glue and clamp?
Keshav
Germany
That’s a relatively common problem. If you use the search function (I used the work flocking) you’ll come across some advise on fixing it your self.
Here’s an example....
bavbob
Boston, Ma
The other question that arises is that the separation can be extreme enough that you can crack the styrofoam or vinyl, bringing them back together. I placed the thing in the over at about 120F in hopes of reuniting the seperated parts and it was a no go. I tried to do this in steps to slowly bring them together and still no go. Any other ideas?
Honolulu
Honolulu Hawaii
The "Rubber Gasket Rejuvenation" thread has a suggestion to make old gaskets pliable again, to soak the part in a mix of oil of wintergreen and alcohol. Might try that on your vinyl prior to glueing it back onto the steel.
eriknetherlands
Netherlands, Eindhoven area
I also had this problem, and I tried clamping it down with some nasty glue.
Put it away to come back 24 hours later to discover...
That It just snapped, and it is now showing a 10 mm / half inch wide split on the visible side over the full width. Turned from half decent into crap.
Not sure how the foam will react if you soften the vinyl, essentially you're (lightly) dissolving the vinyl, but how will the foam hold up?
aearch
pleasant hill , ca
send it off to just dashes
ive only had excellent result from them and they did a my whloe dash and spr\eedo cover and bottom and side panels
in quick order
others havent faired as well
i called a head of time and it was excellent service
i have one more part to do w/ no trepidations
Wladek
Gdansk, POLAND
For best result - rust need to be removed mechanically or chemically (your choice).
1. Cleaning
2. Degreasing
3. Rust converter
4. Good automotive water resistant elastic adhesive.
5. Fix with clamps
