I have weber downdrafts right now on my '74. The engine, however is a later model with no mech fuel pump provision. I'm currently using an electric pump like this:
It is now starting to crap out on me, particularly when the engine gets warm in traffic. It may just be getting old, or perhaps it's because it's currently mounted to the engine block... Anyway, after a momentary failure yesterday caused me to back up tunnel traffic (sorry Alameda!), I'm looking to replace it. Rather than putting the same set up back on, I want to move to an in tank setup. I intend to use the low pressure feed pump from an early E24/E28, which I understand will drop right in. Not only will it be quieter, but it will make swapping in a high pressure pump a quick job if/when I decide to go EFI.
A few questions:
1.) Can any one confirm/deny that the early E24/E28 pumps are drop ins? I've seen a few posts to suggest they are, but nothing definitive.
2.) Since I have a later car, what are the chances I have untapped wiring already in place to run the pump? (ie did CS/CSI cars share the same harness)
3.) If no to #2, any recommendations on where to tap an ignition hot source near the rear of the car? If not a large enough gauge, I'll run a new circuit/relay for it.
Thanks!
-Lloyd
A few questions:
Thanks!
-Lloyd
