Goodnight85
For Sale: 1972 BMW Bavaria – No Engine or Trans, otherwise complete/included – Dulles, VA
I am selling my '72 Bavaria project, hopefully someone will have the time to finish it and enjoy it. All it needs to run and drive is an engine and trans (came with a 3.0 liter M30 and a 4 speed manual trans). It is a 'stripper' model; no sunroof, no radio, no rear sway bar, no a/c, and no power steering.
I have almost all of the other original parts needed to make it run:
Please email me at [email protected] if you have any questions or need additional info.
$2000 or best offer
- currently installed: front subframe (was removed, painted and installed), steering system, rear subframe, rear diff, suspension and control arms. Also has new Kumho tires on the original wheels. It rolls and steers very easily. Ireland Engineering all-aluminum radiator. Front right caliper was replaced. Ireland Engineering poly engine mounts
- Included, but not installed: red 5 blade cooling fan, original oil pan, brake booster and master cylinder, axles shafts & hardware, driveshaft, exhaust system, original alternator, starter, crank pulley, distributor, washer bottle & pump, trans cross-member, front lower timing cover, 12 rocker arms, Ireland Engineering (IE) extended wheels studs & nuts, IE poly trailing arm bushings, Momo steering wheel adapter, OEM trans mount (rubber), new distributor cap, rotor & wires, new Bosch blue coil, original thermostat housing and some heater hoses, original expansion tank & new cap, new upper & lower silicone radiator hoses, tons of original misc hardware
$2000 or best offer
