Rek
I have what appears to be excessive engine movement. This translates to movement at the guibo when accelerating in first gear - although I have not been able to verify this is the cause.
I have a B34 engine installed from a 535i E34 (Alpina B10). Which engine mounts have people used when replacing the engine? The original E9 ones or the E34 mounts?
I will check for tightness but cannot see much movement. Also - the mounts may be after market parts. Has anyone had experience of such and are their inferior products out there? I was thinking that the rubber might be softer or something similar.
Normal driving seems fine, but too much revs in first and the drive train vibrates.
