Aussiecsi
Hi All, my car has recently developed an issue when engine is cold . When it eventually gets going ( after numerous engine stalls , very rough idle etc ) it seems to be fine once it eventually gets to running temperature and fires up straight away on restart . So, this is what has been done so far to try and troubleshoot :-
- There is power to cold start relay /timing delay switch plug .
- The cold start relay has been tested in another d-jet E9 and works fine .
- The cold start valve has been "hot wired" direct to the battery to test if functional... it "fires" .
The upshot is that something seems to be going wrong between the relay and the cold start valve .ie no current is reaching the valve . My gut feel is there is a ground/earth issue but this stuff is not in my skill set. Hope someone can assist . Cheers, Simon
