All is well......
Discussion in 'Off-Topic' started by scottevest, Jul 19, 2018.
  1. Ohmess
    Ohmess I wanna DRIVE! Site Donor $
    2,253
    343
    83
    Vienna, VA
    Scott -- I had a variation on the blue wire problem Chris mentioned. The blue wire in my car had broken and been repaired with a solder joint. Over time the solder joint deteriorated increasing the resistance in the wire. Because of this increased resistance, the voltage flowing to the alternator was decreased and the alternator pumped out more juice in response to this erroneous signal. Fried both my battery and the diodes in my alternator, but thankfully nothing else in the car.
    scottevest likes this.
  2. scottevest
    scottevest Well-Known Member Site Donor
    1,316
    167
    63
    Ketchum, Idaho
    I can’t believe how complicated this all is. Thank you so very much. I will confer with Carrie on Monday unless you guys think I should have a mechanic do this work. Just can’t wait to get the car on the road
  3. Stan
    Stan Well-Known Member Site Donor
    View My Garage
    5,132
    286
    83
    Newmarket, New Hampshire
    This is actually dual exhaust all the way from the front
  4. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    Getting closer.... Just talked to Benny and he agrees that subject to below, I will be on the road this week. I shared with him the information from here the alternator issues. I have a longer list but not bother Benny with the small stuff, e.g. fixing the BBS wheels, etc.
    Benny,
    I hope you had a great weekend.
    Other than minor items, e.g. re-attaching numbers, it seems that we are near the end, subject to the list below. I think this list represents the remaining items:
    • Hood is not closing/opening properly, causing the paint to scrap on the front leading edge, drivers side. I believe adjustments are needed and then paint repair on leading edge.
    • Windows not closing properly - first attach to charger to see if issue is not enough power or requires adjustments to ensure going up all the way and properly closing.
    • finish painting/buffing on passenger door, and reattaching the trim, where new paint is
    • Any additional work needed for fisheyes, etc.
    • alternator issues: I have someone standing by today that can advise Gary on likely issues on the phone. It is likely something super simple.
    • Drain Test - soak with water to ensure nothing leaks in
    • final detail and review
    I can take care of the tires loosing air, headrests, and subwoofer, etc.
    I am super excited. Please let me know your thoughts on this.
  5. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    UPDATE:
    The ebay seller walked Gary through things and was able to get power directly to the dash with alternator producing power, so the alternator works fine, and likely the other one did too. Whew.... He was VERY helpful, and I highly recommend him.
    He thinks it had something to do with the type of lightbulbs used, which although were not LED, may have been different, thus causing the issue. I am hoping Gary can track this down as I am now more certain than before that the problem was caused by switching lights or removing the dash and disturbing a wire or something. I hope and trust that the added costs for chasing this down will not be significant. Not sure if I should be responsible for paying these costs, but not going to argue at this point. I just want to get on the road. This is a microcosm of what a restoration can be like....
    Gary got the passenger window working fast, but now has a bit of a gap. He is going to address, then deal with the driver's side, then the hood, then I'm on the road....by hopefully Wednesday.
    I can't wait.
    teahead likes this.
  6. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    Benny just called. They found the issue. There was a loose wire behind the dash. They had to take the instruments out to track it down. I'm hoping this won't cost much, but fear that is wishful thinking. Benny said I will be on the road by Thur or Friday, assuming no other issues.
  7. Stan
    View My Garage
    5,132
    286
    83
    No matter what it costs, at this point you must get everything right. As my dad said "you ate the whole pig, might as well eat the tail"
    Markos likes this.
  8. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    Now I understand where the expression, "it's like watching paint dry" comes from.... Painting/restoring a car takes forever. I recall in April being asked to overnight misc seals etc. in with the hope/expectation of it being done then. Down to a very very short list, but still not quite done. Apparently, lots of time working on getting the windows to close without gaps took a bit if time this week, and now the switches are screwed up a bit.... You guys were right about knowledge of these cars being helpful in the reassembly process especially. The windows and doors were perfect before we started, thanks to Bill Arnold in SF, but apparently getting them back together is not simple.
    Fingers crossed it will be ready today, but not holding my breath.....
    It will almost be Fall by the time it is done.
  9. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    OMG... SOOOO EXCITED. Benny called me up shortly after I posted this and asked me to come down to take a look. WOW!!! Looks amazing!!!! He is making EVERYTHING right. The paint looks incredible.
    Some minor things to take care off, but I am confident all will be done to my satisfaction and his. The next coupe is on the way to him, and it will be frame off restoration. I assume that some of the lessons learned on my coupe will be applied to the next one.
    Do you want me to document that one, not to the degree of mine but a bit. I know Benny appreciated all your help, and has told me so.
    Here's a live video done when I first got there:
    Hi-res walk around:
    Need to deal with the BBS wheels leaking. I will refer above to the suggestions.
    JDH, Stan and dang like this.
  10. JDH
    JDH New Member
    13
    12
    3
    Denver, CO
    Wow, great walk around. Beautiful! I could look at this car all day long.
  11. JDH
    JDH New Member
    13
    12
    3
    Denver, CO
    Scott, I need a better look at that front spoiler when you get a chance.....
    But maybe that's the point. It doesn't make itself too obvious. I like how it is "hidden", and it definitely accentuates the shark nose. Good choice!
  12. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    I agree. I bought the spoiler from CoupeKing without really researching, and was nervous I wouldn't like it, but I love it. The only thing I'm not sure of is the rectangular holes. Rectangular Fog lights I think would look odd, and not sure if intended for airflow or ?? I may try to see what rectangular fog lights would look like by photoshopping them in. BTW, assuming Benny wants me to document the other coupe he is doing soon, I think I will do so on Facebook e9 groups instead of here. Seems that not everyone appreciates my videos. Open to your constructive opinions. I can post just technical questions here and occasional videos but share much more on Facebook, which seems a bit more about sharing than this forum.
    Open to your thoughts.
  13. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    me too!
  14. autokunst
    autokunst Well-Known Member Site Donor $$
    1,168
    453
    83
    Wisconsin
    Scott, I believe the holes are there to ventilate your front brake rotors. They are meant to stay open for that purpose. The car looks great.
  15. StephenZ
    StephenZ Active Member Site Donor
    164
    46
    28
    Valencia, CA
  16. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    StephenZ likes this.
  17. bfeng
    bfeng Well-Known Member Site Donor
    1,551
    262
    83
    Massachusetts, metrowest
    "frame off" is a bit of a misnomer for E9's
    There is a front and rear subframe but no major chassis frame. Maybe better to call is a bare metal restoration.
    In regards to your question of why it's so complicated when cars are all basically the same ...
    (1) Many restoration shops are run by guys with passion and deep hands-on experience, but who are not good business/operation people. this leads to needless operational complexity. Things like detailed job specifications, change control process, and professional project management is what enables engineering companies to design and build tremendously complex new systems on time/budget. A small application of such principles (as you well know as a business owner), could make a big restoration shop much quicker and more efficient too.
    (2) specialization: you've seen that while there are really NO E9 specific items when it comes to body and paint, there ARE a lot of E9 details regarding trim, mechanical, year on year changes etc. Plus there are period-specific specialties such as electrical systems, suspension, wood, trim, etc. For a shop to do everything efficiently and with high quality they generally have to have some specialization to a limited range of cars and periods, and subsystems.
    John
    Markos and scottevest like this.
  18. scottevest
    1,316
    167
    63
    Ketchum, Idaho
    John, that is my assessment too, without any real prior knowledge. Makes a ton of sense. Benny and team love what they do and are good at it, but could benefit from project management, as could most businesses I encounter. Ultimately, I am very happy with the end results or so I hope to see later this week once the final bits gets sorted out.
    Things like getting windows operating properly would benefit from experience. As things stand, if they can't sort out getting the gaps etc out of the windows, I am inclined to find a shop in SLC or SF to address this so I can get on the road. Other than that along with the repainting on the passenger door and some minor fisheyes that can only be seen when you look at certain angles now, vs. before when they were very apparent on most angles, everything is done.
    Need to sort out the BBS wheel leaks too, but otherwise I'm on the road by Thursday I believe, finally.
  19. bfeng
    1,551
    262
    83
    scottevest and JayWltrs like this.
  20. adawil2002
    adawil2002 Well-Known Member Site Donor $$
    View My Garage
    2,798
    374
    83
    Brunswick, Maine
    Regarding the BBS barrel air leaks. May have to, I hate to say it, have them rebuilt at a wheels shop. When I bought my 16" BBS RSs one wheel had a cracked rear barrel. I was able to just buy the rear barrel and have the wheels rebuilt by a wheel shop.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
