Exploring engine swop options for my coupe (72 Csi). Looking at a Euro spec 91 E34 M5 engine. Has anyone done this and what are the main issues/ challenges?
Has anyone ever tried to squish the V12 into and E9?
Have you ever seen the size of an M70 or M73 and the amount of electronics
required to make it run?
I am on the lookout for a S54... has anyone done that engine?
The electronics are a nightmare. A group of kids from MIT took quite some time to swap one into an E30. I suppose you could go full standalone with a high-end Motec (for biVANOS control) or lock the VANOS and use a simpler system at reduced power.
was looking for a parts car M3. Something between 2004 and 2007
That's what the MIT kids had, and it still took them more than 6 months. Rob Levinson (of UUC) has done several S54 swaps as I recall, you could ask about it. There's also a few S54 swap threads floating around. It is not trivial.
Plus, a slightly modded S38B36/B35 will make the same rwhp and more tq than the S54, based on the dynos I have seen. The S38B38 destroys the S54 in terms of power output.
I would think the electronics woudl be fairly straightforward, as long as you have the DME for that engine. If not, then I'd start with abare unit as several here have described (Megasquirt or Split Second). As long as you have the I/Os to run everythng on the engine, the electronics is pretty easy (wiring and signal conditioning). The crunch is the software. You have at least injector control, timing control, and VANOS outputs. Maybe a few others, and various inputs (air temp, air flow, crank position, TDC, throttle position, engine RPM, maybe a torque sensor, etc.) and so you have a complex engine map that can probably only be really worked out using a lot of dyno hours.The electronics are a nightmare. A group of kids from MIT took quite some time to swap one into an E30. I suppose you could go full standalone with a high-end Motec (for biVANOS control) or lock the VANOS and use a simpler system at reduced power.
