Home
Forum
CS Registry
Tech Info
Links
Calendar
Donations
Go Back   BMW E9 Coupe Discussion Forum > E9 Forums > E9 General Discussion
Reply
Thread Tools Display Modes
  #1
Old 05-21-2009, 06:50 AM
ES 1800 ES 1800 is offline
Default 3.O CS Wiring diagram
Would anyone be willing to make a high quality photo copy of this wiring diagram? Every one that I can lay my hands on is unreadable. I guess another alternative is a very high resolution scan that I could print out. Others have sent some scans but they lack the resolution necessary for me to read.
My car is a '73, produced in April of '73. US model, manual transmission.
BTW, I was at Carlisle las weekend and met Doug, the producers of Prospero's Garage Wiring Diagrams. What a great guy. He has done everything possible to attempt to help me, inlcuding sending 4 of hsi diagrams home with me, but none of them works with my car.
Thanks in advance,
jim
__________________
Jim P
'67 Volvo Amazon
'73 Volvo 1800ES
'73 CS 3.0
'74 Volvo 145
'05 Nissan Titan
'05 Prius
'10 Prius
'57 Case
'79 and '08 JD ...
And only 2 drivers!
  #2
Thanks in advance,
jim
__________________
Jim P
'67 Volvo Amazon
'73 Volvo 1800ES
'73 CS 3.0
'74 Volvo 145
'05 Nissan Titan
'05 Prius
'10 Prius
'57 Case
'79 and '08 JD ...
And only 2 drivers!
  #3
Old 05-21-2009, 09:01 AM
HB Chris's Avatar
HB Chris HB Chris is offline
Default Wiring Diagram
Jim,
I thought the Blue Book has the right diagram. I made a copy of one and then enlarged it several times and taped it all together. I have a May `73 car and the US cars have the extra window relays and circuit breakers which makes them a little more complex.
__________________
Chris Macha
1973 3.0CS Malaga 2250609
1969 NK2000 sedan
1970 2800 sedan 2420317
http://www.e9-driven.com/RegistryView.asp?RID=23
  #4
HB Chris's Avatar
Jim,
__________________
Chris Macha
1969 NK2000 sedan
  #5
Old 05-21-2009, 10:43 AM
David David is offline
Default
I picked up the one below off of eBay. Quality is OK, but not all of the relay terminals are labeled.
http://cgi.ebay.com/ebaymotors/BMW-3...sQ5fLiterature
  #6
Default
  #7
Old 05-21-2009, 10:47 AM
Default
These are the diagrams to which I referred in my first post. Great diagrams, just not accurate for my car.
  #8
Default
  #9
Old 05-21-2009, 01:29 PM
acat2002 acat2002 is offline
Default
MY VIN number indicates an early 1973 US version, but there are several parts that suggest its a later '73 version like yours. For example, all of my window motors have the black plastic casing rather than the "sardine can" type. They have have been upgraded at some point, but the point of me mentioning this is that you may have to verify what you find in the Blue Books with what is physically in your car just to be certain.
I agree, the laminated Prospero wiring diagram is great to keep in the shop, tacked above your workbench for quick reference, but I agree, there are subtle differences between Prospero and the Blue Books.
I could email you a scanned copy of the blue book diagram, but don't have the capacity to enlarge it. PM me if you don't receive it from HBChris.
__________________
'09 Cayenne Turbo S
Defender110
  #10
Default
__________________
'09 Cayenne Turbo S
Defender110
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
