bengal taiga
- Messages
- 226
- Reaction score
- 25
My D-Jet crapped out on me. All diagnostics point to a bad Pressure Sending Unit "PSU". To put it bluntly, it won't hold a vacuum. An ex couper tells me it is part no. 1 3631360678 and has a list price of more than its worth. I am also informed that the ECU "brain" is part no. 1 3611355309.
This is the second bad PSU in the past 10 or so years and makes me wonder if there is an LJet or Webers in my future. I am certain I have one spare left, but at present, I cannot locate it. In the meantime, I am able to drive the car with a PSU originally found on a V-8 Mercedes that I just happened to have on the shelf. Despite the fact that I can adjust the small "inner screw" to get a fairly roadworthy engine, the idle is rough enough to make me not want to drive the car until I find my spare PSU or a suitable replacement.
I am aware that Volvo and Citroen, to name just 2 manufacturers, used the same system on their 6 cylinder models. Thinking out loud, it would seem that the ECU and the PSU from such models might be similarly "mapped" so that they might be pressed into service as a bare substitute for the E9's OEM.
This leads to the core of my post. Is anyone aware of a PSU from another vehicle that might prove a viable alternative to the part number/s listed above? If so, what have you successfully employed? Alternatively, is it feasible to consider a joint transplant (using both the ECU and the PSU) from another model?
Thank you in advance.
