bengal taiga
- Messages
- 213
- Reaction score
- 14
Intermittent stalling. Electrical Gremlin?:x
Perhaps you folks might be kind enough to short cut my fault diagnosis.
I have an E9 with 90,000K and the original D-Jet setup. For the past fifteen years I have run a capacitive discharge ignition “Premature” that was borrowed from a 911. I also use a red bosch coil. Compression is 195 lbs./in2 in all six cylinders. Typically engine runs fine from initial startup to redline. The engine will cutout when you least expect it - cold or hot - high speed and at idle - and I had a record four cutouts over the course of the last eight hours.
For those of you who are patient, here is the more comprehensive version:
After the winter de-mothballing I pulled the car out of the garage this morning. She started immediately and ran for two minutes before shutting down. I tried cranking and cranking but not fire. I know there was plenty of fuel pressure by looking at the inline gauge which reads 29.5 psi. I can also hear the pump. I jiggle the primary wires near the coil and the car immediately fired and died again. Bridged the ballast resistor and still no difference. I removed the cd unit and swapped it for another unit. Car started drove it down driveway, left it idling and - - it died again. This time I swapped the coil and the condenser and examined the points and rotor and - - car ran. I drove car 80 miles at extremely high speeds without any problems whatsoever.
Parked car for four hours got back into car, started and after reaching normal operating temperature, headed down the interstate at high speed. Four or five miles into my trip the engine cut out at speed. I put car in neutral and turned key to off position. Engine started to run on and diesel and I think run backwards! The smoke from the air filter and the fact that the vacuum retard hose to the distributor was blown off is a strong indicator. I put car in gear and dumped clutch to shut the engine off. I waited approximately 4-5 minutes before pulling all wires to check for loose connections or shorts or bare wires - and found none. Put key in car. Car started immediately and I drove home. Three blocks from home, the engine again cut out again. Pushed car to side of road. Waited a few minutes and the vehicle started again and has been running ever since.
I have since tried to duplicate the cutting out - without success. I have even taken to spraying all the wiring with a garden hose to see if I can’t induce a short - but I can’t.
Had what may have been the same or similar problem years ago. I can’t recall why, but I suspected the coil. I changed the coil and hadn’t had the problem recur until today. At present, I am concerned since the old gal does not appear to be very dependable. Please consider that the problem has occurred when the engine is both cold and at operating temperature - so I do not think it heat related. Please consider also that I have replaced the CD unit, the coil, the condenser and rotor to eliminate those parts as likely candidates. It did not seem to make any difference. I even rerouted the wiring to eliminate the CD unit and run the engine on the stock points setup - but it made no difference so I reinstalled the CD unit.
I have removed and examined all of the fuel injection related wiring/contacts and they are all clean. I have a spare CPU and pressure sending unit, but find it hard to believe they are the problem.
As it stands right now, the car runs magnificently - except when it doesn’t! First time she ever gave me cause to curse.:evil:
Any decent ideas - are appreciated. :idea:
