WTB- MOMO hub
kwyjibo
Denver, Colorado
FOUND!
Anybody out there have the solid momo hub for the E9 (shown as the one on the right in the photo)?
If so, please send me a PM with price. Thanks!
not a photo of my car, but here is a photo I found on the internet of the smaller hub being used to mount the early Alpina/MOMO steering wheel into an E9
That is one beastly hub! It fits but the horn won't work. I have a 2002 hub now that I'm trying to replace.
Can you describe (maybe show a picture???) why the wiring from a 2002 hub won't work? What's different from an E9?
Would an E3 momo hub work?
e9 has the horn contuct brush on the steering column not on the hub like the ebay item. The horn ring should be in the hub like the one on the right in this pic:
Questions
So does this go to a 2002?
Is it the tab that matters?
Thanks,
Looks like the brass ring on the back of the steering wheels are removable? Seems that can get transplanted to one of the aftermarket hubs? Anyone do this?
Yes I've done that, I took the ring off my stock bus wheel and mounted it on a wood Nardi once.
If that is the tab that comes out and fits onto the steering column in the 3 o'clock position (under the blinker switch) then should will work. The ones that are for 2002 are the thick ones like in the pic I posted - hub on the left side.
Thanks,
Hi there,
All hubs, Neue Klasse, 02, E3, E9, E12, E21, E23, E24 up to 1983, have the same diameter and splines. They are interchangeable.
The odd one is the BMW 02 hub. It doesn't have the contact ring, it has an contactpin. Here's a photo of a 02 hub;
Seller shows it will fit 77-86. In approx late 82 or early 83 the hub splines changed from fine to coarse. They are not interchangable so I would be careful on the after market EBay adapter. If the Momo adapter is fine splines, it should work
The splines are the same from 2002-pre 83 model cars E3 E9 and E12. So the only difference I am aware of is the horn ring.
BTW, just received this in the mail:
http://www.ebay.com/itm/111805255585
And it works great! Just gotta add a large ring terminal and ground wire on the big mounting nut to your steering wheel horn, in addition to the wire that already comes with it. No biggie.
Eventually, I'll repaint it w/some texture paint to be more like the steering column.
Sure beats the look of the Momo accordian hub or a $200 used solid Momo hub.
I'm surprised to see my old thread sitting at the top of the list.
Nice find teahead, for others thinking of the same hub, please post photos or comments on it once you have it installed. One thing to note is the location of the steering wheel relative to the stalk controls. Of course it depends on the dish of the steering wheel, but some of these hubs need an additional spacer so that the controls are a good distance from the wheel.
