decoupe
(deceased)
One of the issues resulting from the use of the b35 intake manifold is clearance from the stock CS brake booster. This is generally resolved by shortening the booster mounting neck by 3 - 3 1/2" and substituting a Tii booster. This is a lot of work and Tii boosters are becoming hard to find and more expensive with time.
Lee Vuong of Massive Brakes offers a booster delete kit for the e30 (e9 has the same bolt pattern as the e30 and e10) that looks like it will provide the clearance with much less effort with a few modifications to the parts he supplies. I have to confirm this with some of the issues of getting this to work (since I've already done the Tii conversion) but it's winter and I'm up for the challenge and will report back. Lee's comments on my inquiry are below the link.
http://www.massivebrakes.com/brake-systems.php?p=brake-booster-delete
The bolt pattern of a Tii booster is the same as an e30 or a 2002. Therefore the adapting plate will work. The unknown is the distance between the pedal and the surface where the booster bolts. In the worst case scenario, you'll need a longer 8mm rod. The current e30 distance is 130mm (5")
Looking at the e9 pedal box diagram, it should work. You will only need to drill an 8mm hole higher on the pedal stem to increase the pedal ratio from 4:1 to 6:1
I shall have a batch of 50 kits in 10 days. I am currently out of those kits.
Lee
Lee
