FS 72 CSi Stuff A/C 4SPD ....
Bwana
Santa Fe, NM
Got my 5-speed, A/C, and radio installed and I have a bunch of left over stuff I need to get rid of.
This is the expansion exchanger, side panels, fans pretty much the whole unit. It's still disassembled because you should probably check it out for yourself before installing it. Yes, everything works
Hearter assembly. I have no idea as to it's condition because it came out of the Ugly Beast. It looks OK but I've not pressure tested it. The lever work fine
Another view
Blown up/worn out 3.0 X 4-speed clutch assembly.
Not sure what the bracket is, the round things are from a non working fan clutch
e3 front panel (I got it by mistake)
4 Speed mounting bracket
Center console (non A/C) mounting brackets and something from the shifter
Non-A/C front pulley
4 speed stuff
Factory 4 speed. Only about 37,000 miles on it, ran great in the car.
Not sure which this is. One is from the four speed, the other is from the doner 5 speed transmission. The one on my car is from a 635 of sorts
The other one. If you're real interested, I can take them back to my mechanic and identify them
No clue what this is but it came back in the box
Make offers for anything you see that you might want. I'm not looking to make a killing but I do know the A/C parts are worth a bit.
Jeff
I'll go with $250 plus shipping. I'll check on the shipping tomorow, seems like it was around $50 last time
still interested, please check that shipping cost to be sure that it stays reasonable
question, are all the controls, knobs, etc included ?
i need that for fitting a nonAC car with AC, so i will need everything in working condition
regards
I'd like the bell housing for the 5-spd please.
Heading back to my mechanic this AM, will check:
1) Which is for the 5-speed
2) Which configuration it is. I know there are a number of 5-speed bell housings out there, all for the 3.0 and I want to be sure which this is. What configuration are you looking for?
Edit: P/N on housing is 1209780 1.1 225
In the round stamped part is a 81/82
regards
I'm missing the all important thermostat and the fan speed control. I do have the fan knob but not the thermostat knob. I don't know if something can be substituted for those two devices. Anybody know?
You will also have to fabricate your own wiring harness, including relay, plus new hoses and dryer. And you will have to find an electric fan to mount in the front of the radiator. I have two smaller ones that cover most of the radiator surface. Some shops install one larger one, it just depends on what you want. The OEM electric fan is too inefficient, don't use it unless you have to have "original" equipment.
The old wiring harness is included as a "go by". What I'm selling is basically the OEM BMW "core" of the A/C system. All the other stuff can be made by an A/C shop.
Still working on the shipping cost (busy day at work, sorry!)
thank you for the explanations
it is too complicated for me
Sorry! Many apologies!
Not included:
Thremostat
Fan speed switch
Thermostat knob
Dryer (s)
A/C hoses
Condenser coil
Electric fan
Wiring harness
Included for $250+shipping
A/C expansion coil (the fins inside the consol)
Side panels
Expansion valve
Front panel
Fan and motor
Hope this is better!
Missed this!
You mean the cover over the fan intake, correct? Yes, it's still available. It has a crack in but all the pieces are there.
These things are rare as all get out but it's also not pristeen so make me an offer :smile:
Yes, as I'm clueless as to the cost/valuue of a lot of this stuff, I'm checking around for comparable prices. Stand by please!
I am interested in the parts you have at that price point. My coupe had a trunk AC system so I have most of the missing bits already on the car, and I bought a Bav setup a while back which has the switches.
