frogisland
Mr Bump, be aware if you look for a crown wheel and pinion, they need to be a matched pair - they are usually numbered. I managed to find a 10 hole 3.91 in Germany, struggling to find a 3.45 and 3.64.
The pinion output to flange teeth come in both fine and course (latter shown); so make sure you have the appropriate output flange.
Not as straight forward as you might have thought.
CW & P also two varieties, one normal, one reduced drag to reduce parasitic loss. On the crown wheel the gear widths are 30mm (normal) or 25mm (low drag) with similar width reduction on the pinion.
Some questions:
Does anyone know if the medium case CW & P (188mm) fits onto the sideloader LSD?
Are the 10 fixing holes on the same PCD?
If a medium case LSD unit is used in the sideloader diff casing, do the original (e9) output flanges fit the LSD unit?
Does the medium case pinion fit into the sideloader case ok (assuming use of a medium case LSD unit)?
Might be as well for me to buy a complete medium case LSD unit to test (three units to have built for my project)
JP
Some questions:
JP
