Getting this 3.0CSi back on the road
Gransin
Vasa, Finland
Just keep posting pics of the garage build. 1) It's part of the coupe restoration process 2) It adds variety to the thread 3) I don't think anyone could get tired of pics of the garage with that stunning lake behind it.
I'm sure I can continue to share some pictures of the garage build aswell, but I'll probably dump a whole load of pictures later instead of bumping this thread every time there has been a little progress.
Right now I can't wait for the ice on the lake to melt away! The ice cover is still about 60cm (23 inches) thick..
BEAUTIFUL!!!! (yes that is me yelling about how awesome the work looks).
Thank you Andrew!
Gransin
Vasa, Finland
All of my time lately have been put on the garage, but I've managed to get some important pieces sorted, first of all I got my 16" Alpina closed-hub wheels refinished.
I had the centers painted satin black and thanks to Markos who gave me a hint what to search for, I've managed to source some black universal cup holders that fit the bigger center-bore of the closed-hub Alpinas.
Still need to cut the cups down a bit, but that will be done when I have the wheels on the car.
I also bought a ducktail spoiler from daddywad here on the forum, spoiler looks great just need to fit it to the trunk lid and get it painted.
(Our greyhound is checking it out from a distance, still afraid of the table which he managed to break the glass in the day before;))
I've also bought a pair of early 70's Scheelmann 400-series seats from Gerrit, they are in need of new cloth but otherwise in good condition.
He also sold me new cloth that is the closest match to the original Scheel-cloth, so that is the theme for the interior, black scheel cloth and black leather/vinyl.
I have no photos of these yet as they are separated to pieces after the shipping and they are soon off to the upholsterer.
I've put alot of time into the garage project the last month, and it's progressing nicely, can share some pictures to fill out this update a bit.
So this is how we left it last fall, we used it as a carport over the winter.
Started with the first layer of wall insulation:
Put up plastic on the walls:
Here we have installed the wind "guides" that prevents the roof insulation from wind turbulence when it's storming (red arrow), you can also see we put in some 2x4 to raise the attic floor to be able to use thicker roof insulation.
Here we built the frame for the foldable attic stairs:
Time to put up plastic in the roof:
All done with the plastic:
Then started to put up the wood boards:
Then it was time for the wood boards on the walls:
Time to put hard insulation under the attic floor:
Gransin
Vasa, Finland
Floor complete, the walls are left open as the sides of the roof are still not insulated, will put another type of insulation on the sides later.
Then proceeded with panels on the outside:
Then it was time to put in the windows:
Then I had to dig a hole for the drain/sump, I'm going to have a totally flat floor with only a local drop to the drain/sump. Will not play with water inside anyway so I think that's the best solution for me.
Then we filled some more inside and now I just have to make it totally straight before starting to lay down the floor insulation. Also have all the electrical cables that is needed in the attic + outside in place, I pulled some extra cables to the attic so it's easier later when/if I decide to build a carport on the end of the garage.
Then some more panel work:
And this is where I am right now, concrete floor will be done mid-June and the floor polishing guy will come mid-July.
I love seeing the construction stuff as much as the car stuff. I'm building a 400sf elevated deck right now. That is quite the bunker you are building!
Bmachine
Northern California coast
That is so incredibly cool Robert. Is it just you and your dad doing most of that work?
I imagine wood is fairly cheap in Finland, right?
Gransin
Vasa, Finland
Thanks to both of you! Yes it's only me and my father who is doing the recent work, I hired help to build the walls (frames) and put on the roof last summer.
We're going to do mostly everything except pouring the concrete and make the floor level/straight + I'm getting the concrete polished and sealed by another guy later. We could do this ourself but I'm sure I will have a much nicer floor if I hire professionals.
I can't say that wood is cheap, I checked prices on Home Depot and 2"x 2" and 2" x 4" prices were very close to ours.
The outside panels/boards with tounge/groove pattern were twice the price on home depot, don't know how fair comparison that is thou..
tmason
Reno,Nv
Nice job Robert! I love working on construction and seeing it. Looks to be built to last a long time!
What type of heat are you going to use?
Gransin
Vasa, Finland
Thanks Tim!
It's a nice feeling to build something and watch it grow and become what you set out to build!
We're sure trying to build it so it will last a long time but neither me or my father are construction workers by trade, so having friends that can point us in the right direction sure helps alot!
I'm putting down tubes for water underfloor heating, so I have the option to use that later if/when I have to replace the current geothermal heat pump I have in my house. The current heat pump is not dimensioned to heat another 1000sqft + heat loss from the culvert I would need to put down between house and garage.
Another option is to just have an electrical heating element in a small water tank with a pump circulating the water, that's very common around here.
But I'm starting out simple with an air to air heat pump on the wall.
tmason
Reno,Nv
My Buddy here in Reno just finished his Custom Home and went with a heat pump. He owns a Backhoe so he did all the tractor work himself and I think he said it's about 800'of trench at 8'+ deep to do this.
It looks like your going to have apartment space in it?
PS I'm not a builder either but a play one on the weekends!
Gransin
Vasa, Finland
Okay, I have the other type of geothermal heating with a ~220 meter deep borehole, works great with very low heating expenses over winters.
There is no apartment space in the garage, the attic will only be used as a cold storage as we have limited storage place inside the house.
Gransin
Vasa, Finland
Yesterday I bit the bullet... Spent 7-8hours straight to re-size and re-upload all pictures in this thread directly to the forum instead of the old (non-working) photo links to photobucket. Yeah, thank you Photobucket for doing that to your customers, thank you so much!!
But I thought I could upload some more pictures from the garage build at the same time, it's not far from completion now! But I'll start from the last update.
Put down some pipe:
Leveled the floor before putting down the floor insulation:
More stuff done on the outside:
Started putting down the insulation:
Three layers total, except where the two-pillar lift is planned to be installed.
Rebar
Then we started painting the outside:
More in next post.
Gransin
Vasa, Finland
Preparing the form for the ramp outside:
Stainless-steel angle irons with insulation pressed in between to stop the cold from getting in.
Put down rebar and the form is complete.
Floor-heating pipes put down on to the rebar:
And then it was time for concrete, luckily I left this to professionals.
Next day:
More in next post.
Gransin
Vasa, Finland
Then I got the rain-gutters installed + "snow barrier" on the roof.
Next up was the floor polishing, I hired proffessionals for this too, turned out great in my opinion.
Then I pulled some more cables.
Next up, more wall insulation.
Then we started with the OSB boards
Then plaster boards in the roof:
Roof finished
More in next post
Gransin
Vasa, Finland
Next step was to put up the plaster boards on the wall, didn't take any pictures while we did it because it was a bit stressful as the door-installer was comin the next day :eek: Here with lift-doors installed:
More work done on the outside around the doors, smaller door also installed + lights
Prep for paint on the inside:
Half-way painted + insulation protection boards installed:
Lower half painted grey and after that I installed the lights + sockets and got the power turned on:
Stairs:
And a little more work done on the outside, just some painting left to do, otherwise finished with the outside!
And this is where I am currently :)
Gransin
Vasa, Finland
Thanks guys! Still some finishing touches to do on the inside but I think it's looking great already:)
The e9 got to see some daylight today for the first time since March, started and did run fine. Will be transported to the garage sometime soon, or at least before the weather changes.
Bmachine
That is really awesome Robert, congratulations! It goes to show, taking care of a car with any degree of passion involves a lot of seemingly unrelated peripheral work.
But it is really interesting to see what technique you are using for dealing with the weather out in Finland.
Side note: Are those overhead lights LEDs? I converted all my fluorescent tubes to LEDs and there are really awesome. Not the least of which is the benefit of not having to worry about the kids playing ball in the garage and risking to hit those stupid fluorescent to see them crash on the floor, spilling mercury everywhere. Plus instant on, better lighting, lower electricity, etc...
